I have issues with several mRo Control Zero OEM flight controllers where parameters are lost or changed on reboot.
I’m trying to use Dshot600 on Arducopter 4.1.4 to control 6 motors and everything works well until I reboot. Then the BRD_PWM_COUNT is set to 2 and the next time I boot only 2 motors are working.
I also try to use the outputs 7 and 8 as relay which also works until reboot. But even if I do not do that the BRD_PWM_COUNT still changes.
I’m kind of desparate, any ideas what to do?
