I have a team of pilots flying identical drones. Each uses Mission Planner. I can standardize the version and build of software each is running. Is there one config file (or one standard set of files) that contains ALL of the parameters users can set in MP? Does MP use Registry tags in Windows? I would like to set up one PC and then replicate that PC’s complete MP configuration to everyone else.
Settings are stored in user’s Documents/Mission Planner/config.xml file.
If you have custom checklist it stored also there in checklist.xml
and if you configured joysticks then a josystick*.xml files are also stored there.
So It is enough to copy these files into a new install.
