Any reason why MP would not run on the Microsoft Surface Go?
Surface Go
Considering purchasing and may use for field use at times. I know it has a USB-C that will need a dongle to connect telemetry.
MP is available in the windows store, and the minimum requirements shown there are much less than the surface go. My guess is mp would also run on much cheaper hardware.
We have been using it in the past, it works ok, monitor not great in the sun and a bit slow overall.
The sun part I expected, the slowness is a problem because the Go seemed to be the best alternative to a laptop, which is more hardware than I would want to carry. Thus, the search will need to continue.
I run MP on my surface go all the time. Perfect device for it.
I’ve recently loaded mission planner onto my surface go. The app just crashes whenever I try to connect to my app 2.6. Is there a version that works for surface go with apm 2.6?
