I have upgraded 2 machines in the last week and both for some reason messed up the FRAME_CLASS.
In each case they where set to 0 and I had to manually change them in the config listing.
I have two more machines to do in the next week, will see if it happens again.
Hi @rickyg32, just a suggestion, try to diff the param files from before and after you set the new class. Happened to me once and many parameters seemed to change.
Yes I started doing that after this upgrade gave me the class problem.
Now I even do it from one tuning event to another…Just in case I fat finger something.
Bạn chế tạo hexa là dòng 6 cánh, firm 4 cánh và tham số 4 cánh sao dùng đc, bạn phải tìm firm và tham số 6 cánh load lại mới đc
