I have a setup with T motor F45A ESC. With MOT_PWM_TYPE set to Dshot and servo outputs set to AUX ports and safety switch disabled, the motors wont spin. When changed to PWM, the motors spin. ESCs are calibrated and motor test works fine.
But when trying to fly, the copter wont takeoff even though max throttle is given. They just spin at low RPM.
It works now with dshot protocol. But the problem with the motors slowing down after few seconds still persists. I turned off Low RPM Power Protect, also tested this with the ESC directly connected to the receiver channel 3. Could this a motor timing settings issue?
