discodude
(discodude)
1
Hello All
I am new to the forum and have been flying and building quads of all shapes and sizes for the past 2 years,
I am trying to install a Pixhawk on my TBS disco
Tiger 2216 800kv and ztw 40Amp escs
I have done all calibrations including ESC.
But when arming press safety, it goes red then bottom right on tx i get nothing.
I can test motors and they work fine in setup, i do need to raise the number to 8- 9 % to get motors to spin.
So i am confident all wiring is correct.
When i Cal ESC i am able to throttle the motors, so happy all is connected here again. I just can not get the thing to spin once armed.
I have read many threads, and posts, tried changing some parameters but nothing.
Would really appreciate the help…
Thanks
Discodude
TCIII
(Thomas J Coyle III)
2
@discodude,
Please provide tlogs and/or dataflash logs to help troubleshoot your issue.
Regards,
TCIII GM
discodude
(discodude)
3
Thanks I sorted it out
When I went to extract and send the log file I noticed messages stated rc not calibrated.
It looks like once you change the parameters you need to re run the cal process
Once done all worked well…
Now just as I got ready for test hover I managed to nock the button safety switch and break the red and black wires off the button
Does any one have a pic or a pin out so I can re solder
My yellow is still in place
Andrew
Sent from my iPhone using Tapatalk
arruntus
(arruntus)
4
Hi
Same thing happened to me. I not find the photos I took when I broke it but…
Here’s the wiring diagram
https://pixhawk.org/users/safety_switch
