Hello, I have set up a configuration where all 3 motors tilt to VTOL from the forward flight for my tricopter setup. The motors however are unresponsive in QSTABALIZE, QHOVER, and input from the controller to motor 1, motor 2, and motor 3, but I know the controller works since the throttle of Radio Calibration is responsive and so are the elevons. The 3 tilt servos are responsive to input from changing modes(unlike throttle) but don’t seem to move and try to adjust when I’m in QSTABALIZE or QHOVER. The 3rd motor is also at zero and for some reason doesn’t respond to the motor test. Also, the throttle responds when I add a throttle part instead of motor 1, 2, etc., I don’t know If that helps. Do you have a fix for this issue? Am I supposed to use different motor outputs?
I tried this abs fixed the 3rd motor issue, but the motors are still unresponsive? My remote is armed and when i add a throttle servo output it works fine, dont know if that helps?
IM having the same problem did you find a solution , i built a t1 ranger with the f405 wing vtol flight controller and im having the same issue , test motors work but no input from the radio only if i put it in RCIN
