Motors not spinning in same speed#cube orange+#Hexsoon edu 450
Hello everyone,
I recently started building a quadcopter using the Hexsoon EDU 450 frame with the Cube Orange Plus. I’m having some problems:
  1. Motor Speed Issues:
  • When I arm the drone, only Motor 1 (CCW) / Motor A spins, while the other three motors stay still.
  • When I increase the throttle to 15%, the other three motors start spinning, but they are much slower than Motor 1.
I’m using the 4.5.5 firmware on the Cube Orange Plus.
Any advice or help to fix these issues would be greatly appreciated.
Thank you!
Thanks for double posting, we really like that. Please do it again soon. The more posts the better. If you post three times you get an answer three times as fast, for sure!!!
you can try to calibrate your escs again and you can also Email us for more help.(contact@hexsoon.com)
