Have build my first Quad, a HexSoon EDU450 (motors and ESC that came with the kit + 3S 5000mAh Lipo) and done all pre-flight setups and checks.But when spinning up the motors, its seems like it lack power. The motors dont manage to lift the quad of the ground.
Also I see that two of the motors is starting later than the other two… Anyone seen this before?
Yes, I have tried to calibrate the ESCs, but from what I read, it seems to be the issue (or at least the issues described is very similar…)
Have redone the calibration and will test again as soon as it get light.
I replied in the edu450 thread, you MOT_SPIN params are wrong
Use these:
MOT_SPIN_ARM,0.12
MOT_SPIN_MAX,0.95
MOT_SPIN_MIN,0.09
You can change MIN and ARM if required, but usually never change MAX
