Hello everybody,
I have encountered a weird behavior during the motor to ESC connection.
I have carried out ESC calibration using a motor and it spins properly, then I have tried another motor with the same calibrated ESC but this motor does not spin properly and it starts heating, so I have decided to swap any two cables and the motor starts spinning as expected.
This image shows exactly the procedure I have followed, first configuration does not work but swapping cables solve the issue.
Any of you can give advice on this issue? I did not expect such behavior, I thought the second motor should work despite the order cables.
Motor used: T-motor MN501-S KV240
Esc used: T - motor AIR 40A
Also when I tight motor to rigid support it seems like it tights itself and the spinning part becomes harder to rotate, is it normal?
Any advice is appreciated best regards.
