When I start Motor test process at 5% throttle some motrs spin in my hexacopter. but some motors won’t spin and the only have the beep sound. why is this happening ?.
at the first take off My drone fliped.so I went through the motor test and this was happen
please help
When you do find the value that makes them all spin, reliably every time - you set that as MOT_SPIN_ARM
So if that value is 8% in motor test, you set 0.08 in MOT_SPIN_ARM.
Then you would add 0.03 to that and set MOT_SPIN_MIN, 0.11 for example.
