Fortunately found this out on a bench test…
When I switch mode from STABILISE to LOITER the motor stops ?
It’s a Flying Wing, MP v1.3.72, FW v4.0.5.255
I have GPS 2D fix, 12sats HDOP 1.12.
Battery with cells at 3.7v LiIon
I’ve checked all I can think of, any ideas please?
It needs to be moving about and and have some air speed.
Should be fine to go ahead and launch, the only major gotcha in plane is to double check the surfaces are correcting in the right direction and the sticks are also in the correct direction.
Yep, I’ve done this bit, I get confused at my age HAHA so I have this crib sheet…
TX Stick Test
roll stick right - right evelon goes UP
roll stick left - left evelon goes UP
pitch stick up - both evelons go down
pitch stick down - both evelons go up
Auto-stabilise (angle mode)
wing rolls right - left evelon goes up
- right evelon goes down
wing rolls left - left evelon goes down
- right evelon goes up
wing climbs - both evelons go down
wing dives - both evelons go up
