Hi Team, I’m observing odd motor behaviour while throttle is at 60% only. After arming the drone even giving minimum throttle stick input, all the motors are spinning at max RPM. I attached the log below. Thank you in advance!
Log
Quad Specifications:
FC: Customised
35A 4in1 ESC skystar
5500KV motors
Is this another irrelevant bench test of the motors w/o props using the transmitter?
Or it’s this.
NO.
The test is being done with the full setup.
