I was going through my log files and noticed MOTORS_INTERLOCK_ENABLED and MOTORS_INTERLOCK_DISABLED events after every arm and disarm event. Pre-arm checks are currently disabled and I don’t have interlock programmed on my radio at all…?
It is normal, Interlock functionality (not the switch but the functionality) is enabled when the following rules are met
motors->armed() && !ap.in_arming_delay && (!ap.using_interlock || ap.motor_interlock_switch) && !SRV_Channels::get_emergency_stop();
However it has nothing to do with Mission Planner, it’s a flight controller behavior.
And one more note, why on earth did you disabled arming checks ???
Ok thanks.
I was doing battery calibrations and my quad wouldn’t arm again because the MP voltage reading was lower than the actual so I disabled them. But don’t worry I will enable them again soon…
