Hi all.
Is there a known issue with the auto log analysis tool?
Im getting a FAIL on the motor balance test but the test gives 6 PWM values on a quad. They are all around 1400 except the 5th which is about 900.
Analyzing the log in more detail shows RCOUT 1,2,3,4 all well balanced.
I have done an ESC calibration but made no difference.
og File C:\Users\Vince\Documents\Mission Planner\logs\QUADROTOR\1\2017-01-21 14-15-51.log
Size (kb) 11237.7626953125
No of lines 133349
Duration 0:08:06
Vehicletype ArduCopter
Firmware Version V3.4.3
Firmware Hash 9a3a0d4e
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = NA -
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (19.37%)
Max mag field length (619.14) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.48, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = FAIL - Motor channel averages = [1445, 1478, 1473, 1467, 983, 1494]
Average motor output = 1389
Difference between min and max motor averages = 511
Test: Parameters = GOOD -
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = GOOD -
This particular test is going to need quite an overhaul to account for
changes in recent master.
In the meantinme you can ignore the values for the other channels.
