Monitor Voltage and Current of the PX4 FMU+IO
Is it possible to monitor voltage and current of the PX4 FMU+IO (v1.7?
MP just displays voltage, but I cannot figure out how to display the current.
I followed Randy’s instructions and I can display both values out the Pixhawk, but I cannot do the same with PX4 FMU+IO.
Any suggestions?
Hi, I have a PX4 + IO and I think the default current sensor input its currently broken on the PX4.
I use the “airspeed” analog input instead. It’s number 11. Its up to 6.6 Volts as it is scaled down 2:1
You will have to use a BATT_AMP_PERVOLT twice as high as before.
This is the issue:
github.com/diydrones/ardupilot/ … t-93466956
planner.ardupilot.tridgell.net/w … d-pixhawk/
Hi there,
Thank you for posting this information.
Just to make sure I understood. Are you saying that I need to set BATT_CURR_PIN to 11 (instead of the default 101) and increase BATT_AMP_PERVOLT to 34 (the default is 17)?
Will that allow to display the actual current in the PM Flight Data display?
