FlowHold mode was never really completed and never worked very well for me in testing. Be careful when trying to use it.
The sonar on the PX4flow is not very good, and not recommended for use from what I remember. Try using something like a TFmini which is pretty cheap and much better overall.
Here I have attached a .bin file where I have tried FlowHold mode. And as written in the wiki it gives the wobbling result and also the same told by you. But I didnāt observe any kind of drift in a specific direction.
So do I consider that PX4flow is well calibrated with FLOW_FXSCALER and FLOW_FYSCALER parameters and after adding TFMini-S Micro LiDAR, wobbling will stop? And It will work with Loiter.
In my case, I have to first take off in AltHold mode and after 1 m I m able to change to loiter mode with PX4flow. I would like to request the ardupilot wiki editors kindly correct it so that in future no one confuse there.
Hi Yash. I am having the same problem. When I activate loiter mode at 1m height, quadcopter goes up and does not hold position. Were you able to get quad to loiter in one position? My quad starts to drift itās position as soon as I put it in Loiter mode.
I would like to suggest first calibrate your flow sensor as per documentation dont miss single step. And then before to do second flight test check flow sensor performance in flowhold mode instead of directly try in loiter mode.
To check performance in flowhold mode first take of in altitude mode with rangfinder on vehicle and engage to flowhold mode and check performance of vehicle.
For safety be always ready to switch back in altitude hold mode in case of quad is going out of control in flowhold mode.
I hope after this you will achieve good position hold.
Ours still doesnāt work, using MTF-01 optical flow / lidar. Iām not happy with the Ardu instructions and the MTF-01 setup manual, however, the MicoAir guys do respond and next week Iāll be troubleshooting with them. Itās very annoying. Everything done as per instructions without fail, tried on 5 different sets of drones. No avail. GPS + baro + compass + IMU0 + IMU1 + Lidar + opt flow + EKF switch + EKF home set + Home Set. Doesnāt work. 4.5.7.
