MMC Launched Etlas Mobile——a Next-Level Handheld GCS of High
MMC L a unched Etlas Mobile——a Next-Level Handheld GCS of High Integration
Etlas Mobile
1. High Integrat ion
Etlas mobile covers functions of real-time control, route planning, image display and payload control. With two frames on screen, users can capture all information at one glance. It combines functions of remote, computer, image transmission, antenna and monitor, sparing the effort of matching different devices.
2. Image and Data Transmission in One
Etlas mobile integrates high resolution image link, data control station and remote-control link for bidirectional transmission. It supports SBUS, HDMI and other connectors, allowing for real-time bidirectional data transmission. Image-data integrated transmission spares the problem of frequency interference and incompatibility and simplifies the works of system installation as well as debugging.
3 . Touch Control to Switch Frames
Users can simply touch the screen to switch between the ground station frame and UAV frame according to monitoring priority.
4 . Ultra Bright Screen
The brightness of Etlas Mobile screen can reach 1200 nit, which makes it still clearly readable under the direct sunlight.
5 . IP 52 I ngress Protection
Wrapped by silicone cell and sealed with 3M glue, Etlas mobile is of IP52 level, resistant to dust & water and shock-absorbing.
6 . Five-finger Touch Control
Etlas mobile is equipped with ultra-sensitive screen that allows for five-finger touch control and avoids interference caused by accident touch. It is therefore able to work under complex environment with great stability and reliability.
7. 5km Control Distance
Etlas mobile is equipped with a new generation of image transmission that could conduct real-time control from 5km away, which is applicable to long-distance operation.
8. 5-Hour Battery Life
Equipped with high-performance battery system, Etlas mobile can keep working for 5 hours to satisfy the need for long-time outdoor operation.
9. Adaptable to Extreme Temperature Environment
Etlas Mobile can satisfy the need for extreme temperature environment operation, with its adaptable temperature ranges from -20℃ to 55℃.
10. Compact and Lightweight
Etlas mobile measures only 320×142×54 mm and weighs only 1.2 kg, which makes it quite portable and convenient for emergent outdoor flying missions.
11. Strong Compatibility for Extensive Applications
Etlas mobile has multiple data connector ports which makes compatible with various devices including multi-rotor drones, fixed-wing drones, robots, industrial controller and monitoring gimbal, etc.
12. Super Processing Power
Etlas mobile adopts high-performance six-core processor with Android 7.1 operating system. It features super strong processing power and high system stability to ensure long-time stable ground station work.
About MMC
MMC is a leading industrial UAV manufacturer that is devoted to producing high-performance UAV products. It is one of the very few companies that is able to manufacture and customize all-round UAV industrial chain products including commercial drones, flight controller, image transmission, GCS, motor, payloads, battery, airframe, propeller, etc. Its quick-release MMC standardized connector makes all products inter-adaptable. Its mission is to bestow industrial work with greater safety, higher efficiency and lower cost.
Please add a link to product page showing pricing and additional informations like:
What GCS software is loaded?
Can we load other type ?
Is the OS opened ?
Can we add apps?
Has it been tested with ArduPilot vehicle ? ,
Do you Have video ? Test Report ?
What frequency are you using ?
Do you have any certification for radio (Fcc Approval)?
Thanks for making this showcase more attractive and instructional
