I’m just installing an Arducopter v2.8 with Plane 3.4 loaded in my V-tailed Talon. Radio with standard outputs and mixing in the FC.
Everything does as it’s supposed to, BUT the rudder and elevator throws are huge. When I check the Mixing_Gain it says 5. Not 0.5 as it’s meant to. When I try to set it to 0.5, I get an out of range error message, but the input field accepts the value. However, there is no effect on the wild throws.
If I shut down the Mission PLanner and start it up again (assuming it reads the values form the FC), it now read the value “5” again…
Any ideas?
thanks
Mike
