MissionPlanner SITL error
When I try to load my params to SITL heli simulation, ı got following errors:
BARO1_DEVID is marked as ReadOnly
BARO2_DEVID is marked as ReadOnly
COMPASS_DEV_ID is marked as ReadOnly
COMPASS_DEV_ID2 is marked as ReadOnly
COMPASS_DEV_ID3 is marked as ReadOnly
COMPASS_DEV_ID4 is marked as ReadOnly
COMPASS_DEV_ID5 is marked as ReadOnly
COMPASS_DEV_ID6 is marked as ReadOnly
COMPASS_OFS2_Z value is out of range. Do you want to continue?
GPS_CAN_NODEID1 is marked as ReadOnly
INS_ACC_ID is marked as ReadOnly
INS_ACC2_ID is marked as ReadOnly
INS_ACC3_ID is marked as ReadOnly
INS_GYR_ID is marked as ReadOnly
INS_GYR2_ID is marked as ReadOnly
INS_GYR3_ID is marked as ReadOnly
MIS_TOTAL is marked as ReadOnly
STAT_BOOTCNT is marked as ReadOnly
STAT_FLTTIME is marked as ReadOnly
STAT_RUNTIME is marked as ReadOnly
also here is the params I am trying to upload:
18 mayıs uçuş öncesi.param (19.6 KB)
what do I need to do fix this?
I have same problem. I try to run my heli simulation using my params too.
There’s nothing wrong with your system: These parameters are indeed read-only (e.g. STAT_RUNTIME is how long your system has been running for).
What you can do is remove these parameters from your parameter file.
But just getting the errors doesn’t cause any harm.
Also there 96 missing params too in the picture i shared. Is this also harmless?
Is missing params mean, the params ı upload is missing these parameters?
The parameter file you are trying to upload contains parameters that the firmware does not have. This can happen, especially since you are transferring parameters from a real vehicle to a simulated one.
Whether you want to better edit your parameter file to not get these warnings is up to you. But it’s not harmful as is.
Thank you for your explanations.
Thank you for helping me out as well regarding this issue, you made my day :slight_smile:
It looks like you’re encountering issues with parameters marked as “ReadOnly” and some out-of-range values in your MissionPlanner SITL heli simulation. The “ReadOnly” errors typically occur because those parameters are set by default or locked in the simulation and can’t be modified directly. For the out-of-range value (like for COMPASS_OFS2_Z), double-check your values or try resetting them to the defaults. If these parameters don’t need adjustment, you can ignore or skip them, but if they affect your simulation, you may need to recheck your configuration or the SITL version compatibility.
