Hi there! This is strange b/c Mission Planner 1.3.49 was working fine on this device (Microsoft Surface 3), I connected to the Pixhawk 2.1 via USB, updated firmware, parameters, etc., then when I tried to connect via the HobbyBro Modem, it wouldn’t connect. I closed MP and when I tried to launch it again I received the following error:
FATAL Program: Fatal app exception
System.FormatException: Input string was not in a correct format
I’ve tried uninstalling the software 4 times, restarting device several times, deleting root folders (after uninstall) including “C:\ProgramData\MissionPlanner”. I also tried connecting to PH via USB again, uninstalling and reinstalling USB driver and still getting error.
I have another identical Surface, and MP runs perfectly on that device.
Any suggestions?
Thanks in advance!!!
