Mission Planner UI cannot see Holybro Sik Radio USB serial port driver description. Windows 10 PC.
Try to connect with the baud rate of 57600. I don’t always get a description with some of my devices.
Is not the baud rate issue, I can connect properly and I had double confirmed with Holybro’s staff the speed it can support.
I don’t understand what the issue is. The device isn’t reporting a description (not Mission Planner’s problem). It connects fine. This appears to be normal, expected behavior.
