cause of several problems I had with the mission planner user interface I made some changes to the source and I’m wondering if anybody is interested into them, or have other wishes and or complains:
- first thing, I made the way-points taking less space to render to create more complex way-point structures
- I removed the labels and render the altitude and way-point index directly with a small font, I think its important that all altitudes can be seen at once on the map, without taking much space
- way-points are inserted after the way-point that was selected last, otherwise its quite annying to add a way-point inbetween
- higher zoom level for the map
- visual battery warning, big red label if battery voltage drops under the given threshold
some changes can be seen on the attached screenshot
cheers,
tom
