I’m connected to a Pixhawk by 3DR Radio and running AC v3.3.3. Everything other than the 2 items below seem to work fine. The MP Build is 1.1.6038.12291.
With a mission loaded I select the Waypoint Command pulldown box and receive the following:
When I select the Full Parameter Tree I receive the following:
I’m unsure if I have all the correct Mono items installed since others don’t seem to have any problems with 16.04 so the below text file has everything Mono installed on my system:
Everything Mono Installed.txt (29.0 KB)
