I just updated to Mission Planner V1.3.00, when I start for flight plan design, I cannot see the yellow between WPs in the map. Refer to attached picture, whether Mission Planner V1.3.00 deleted the yellow line? Or I made any mistake?
MP needs Home Altitude in Flight Plan Screen, otherwise it will not display the yellow lines…
Home Altitude is automatically set if a valid gps signal is transmitted by mavlink, otherwise You have to set it manually in the field on the right side of Flight Plan screen.
regards, Andreas.
