Just after installation I getting this screen.
What it could be, and how I can fix it?
I have win 7 x64 system.
Can’t attach a file here is link postimg.org/image/i2v3v49an/
@pioneerko,
Make sure that you have MS .Net Framework 4 or higher installed.
From the look of the errors being generated, I would make sure that you have the latest graphic drivers installed on your PC. Do not rely on MS to tell you about your video drivers. Go to the video card’s manufacturer’s website and see what the latest video drivers are for your PC and update if necessary.
Regards,
TCIII Admin
Tried update NET Framework got message:
Same or higher version of .NET Framework 4 has already been installed on this computer.
Now downloading fresh graphics driver, will post if it solve a problem.
Install fresh driver, and NET Framework.
Still getting this error.
@pioneerko,
Did you install the MP using the msi found here: diydrones.com/forum/categori … orCategory
Try posting your issue in the DIY Drones MP Discussion Forum: diydrones.com/forum/categori … orCategory
Regards,
TCIII Admin
After reinstall windows, program start working as it suppose to.
