I am new to Mission Planner, and trying to get everything working. The documentation is comprehensive, and a lot to take in. So far my Mateksys F765-WSE talks to Mission Planner on my laptop via XBee modems; I get GPS fix and location on the map, also RC and stabilization works. I want to have everything working in a rig setup before installing it in my Skywalker fixedwing.
I have MP 1.3.76 running on a Windows 10 laptop. Today I tried Simulation and could not get it to work. Something is obviously missing since I get this message several times from ArduPlane.exe : “MKFIFO failed with No such file or directory”
It seems to me from the documentation, that additional requisites need to be installed. Do I need to install Linux under Windows 10? Or, since I have Ubuntu 20.04 alongside Windows on my hard drive, should I rather run Simulation there?
I got the simulation to work now. After a steep learning curve I could fly a mission with takeoff ,several waypoints, and landing.
Still I get the error messages shown in the screenshot in my post #2. Is there something I should configure to get a clean loading of the simulation, or should I just leave this and continue simulation?
Seems like you’re disarmed.
Arm first, change flight mode to auto and send mission start.
Does your flight plan include a takeoff mission item as the first item?
Mustafa Bey cevabınız için teşekkür ederim , yıllardır önce arm edip hemen ardından mission start komutu vererek uçuş yapıyorum ( 1.3.73 ile şu anda aktif olarak bu şekilde uçuşlarımı gerçekleştiriyorum ) , dediğiniz gibi uçuş modunu auto yapıp da denedim ama yine aynı hata mesajını aldım . MP 1.3.74 e kadar sorun yoktu ama 1.3.75 den sonraki versiyonlarda ne simulatorde nede arazide gerçek uçuşta otomatik uçuş yapamıyorum bu nedenle malesef eski versiyon kullanıyorum . Uçuş planında takeoff komutu var. Hem windows 10 hemde 11 de denedim sonuç yine aynı . Sizin simulator şu anda çalışıyormu ve MP sürümünüz nedir ?
I use MP 1.3.76. To get simulation running I did this:
SIMULATION → Plane icon → Latest (Dev)
Check green CONNECT icon on screen top right
PLAN → Load File → Choose a flight plan already made with TAKEOFF as first command
PLAN → Write
DATA → Actions → Mission_Start → Arm/ Disarm → Auto
In my case, the sim runs now with a “flying” plane, despite error messages during loading of the sim.
I tried same procedure and found a strange simulation.
My flight plan does not have takeoff, it starts from waypoint 1. Before the mission start the sim runs with a ”flying" plane like your case with speed about 2m/sec.
After the mission start the orange line directs the waypoint 1 but the airplane maintains its initial heading and flight speed does not change.
But after several minutes, the simulation suddenly change its behavior i.e. speed increase to around 20m/sec and the plane starts the mission flight.
