Mission Planner 1.3.77 Build 1.3.8110.38294 ArduRover V4.2.3(2172cfb3)
When I change the trim values using Setup->Servo Output and download parameters, the trim values are not changed. Also, if I change RCX_TRIM in the full parameter list and update the flight controller, the RCx trim value in Setup->Servo Output doesn’t reflect this change. The values set in Setup->Servo Output doesn’t seem to affect the parameter list, nor are the trim values from the parameter list reflected in Setup->Servo Output.
What am I missing or misunderstanding?
Dave
