Mission Planner RTK Float vs Fixed
I have a Septentrio AsteRx-UAS GNSS installed on my drone. I am injecting a VRS correction via mavlink and monitoring the GNSS performance via Mission Planner and the Septentrio GUI. In Mission Planner I am seeing an RTK float solution in the HUD with a GPS status of 5. In my the Septentrio GUI I see an RTK fixed solution. Please see the attachment.
I am using the latest build.
I thought I read this was corrected in the latest release?
Dave
can you provide the Septentrio log? just so I can see how its reporting fixed
Michael,
Thanks for taking a look. Attached, please find the text file for the GGA string.
Around time 185119 it goes to fix quality goes to 4 - RTK fixed \
THanks,
Davesept1180 GGA.txt (323.8 KB)
ideally the original source sbf file was what I was after. the nmea stuff doesn’t really help
ArduCopter 3.4.6 doesn’t report RTK float vs fixed settings. You need ArduCopter 3.5 for that. On 3.4.6 I believe RTK fixed is reported as RTK float while float comes in as dgps. This has to do with a MAVLink limitation.
Here is the bin file
Thanks,
Dave
@WickedShell,
The previous version of mission planner delineated between DGPS, RTK Float and RTK Fixed.
Dave
that file didn’t have the info I was hopeing for
I wanted PVTGEODETIC
Can I change the logging to get that?
can you post a screenshot of this
I used rxcontrol to get this
Hi Michael,
I checked PVTGEODETIC and logged a brief session. It took a few minutes to get a fixed solution, but eventually got there. Here is the bin file.
And here is the requested screen shot
Please let me know if there is anything else I can do to help troubleshoot.
Thanks,
David
could you do the same SS just with “mode” expanded
Sorry about that. I noticed the drop down after the SS. I shut my rig down for the night. I send you another one tomorrow.
Michael,
Here is a screen shot with mode expanded. Before I connected, I installed the lastest update.
Here is the bin file with the last two seesions.
Dave
Michael dB is correct, this is an issue because of the changes made to AC3.5, I believe Mission planner changed to support those changes. but in earlier versions of AC report it differently. If this needs fixing then it should become conditional on the version of AC being used. I had this same issue earlier with my septentrio and I confirmed that MP reports float when the AsteRX actually reports fixed.
what Jamie and michael said. is the answer. 3.5 is the only software that supports the correct display.
Ok, thanks.
I’ll wait for a stable 3.5 release before I update. Until then, I know RTK float means I have fixed solution, which is the thing I care most about.
Thanks,
Dave
