I’m working on some plugins for multiple vehicle connected situation.
below code was useful when there are only two vehicle and their firmware version and kind is different :
foreach (MAVLinkInterface mav in MainV2.Comports)
if (mav.MAV.cs.firmware == MissionPlanner.ArduPilot.Firmwares.ArduCopter2)
but, If there is many vehicle that have same firmware, It is hard to distinguish which one is currently selected by user in the mission planner.
I mean, in below scroll bar, user can select various vehicles, and programmer can’t know which vessel is selected in mission planner. :
I chekced that this code effectively found the vehicle that is currently selected by user, but I’m not sure it is correct way to find selected object.
Console.WriteLine("Firmware Version : ");
Console.WriteLine(MainV2.comPort.MAV.cs.firmware);
Im unassure that it will find currently connected vehicle in any situations.
Is there other way find vehicle currently connected? is there any properties on mavlink object to confirm that or any UI object to check that
MainV2.Comports is a list MavlinkInterface objects (ports) all open vehicle connection has a port object in this list. MainV2.comPort is only a reference to a list item.
The items in the list is updated regardless of what is selected in the dropdown.
Comports.sysidcurrent contains the selected vehicle sysid.
Note: Actually it is not only sysid but sysid and componentID. You should take it into consideration if you have a vehicle with a component that communicates via mavlink and has it’s own componentID.
← I know it, I think there is misunderstanding between us, sorry for my long and complex post.
suppose we have to setup specific parameters for only one vehicle that is currently selected(in multiple vehicle connection situation)
How do you know that one vehicle is connected?
and different with your saying, If I change selection in dropdown list, “MainV2.comPort.MAV.cs.XXX” object is changed.
for example, If I select Rover in dropdown list, it will print parameters of rover, and If I select quadrotor in dropdown list, it will print parameters of copter.
