Mission Planner Plugin Programming Question[Custom Window Button Color Change]
Hello.
I’m programming Log-In function on mission planner, with plugin.
I have made login window as below picture
For Forum Question - Login Form Example
Below is the code of Login Form.
public class LoginForm : Form
            private TextBox usernameTextBox;
            private TextBox passwordTextBox;
            private Button loginButton;
            ButtonOverlay buttonOverlay;
            public LoginForm(ButtonOverlay _buttonOverlay)
                buttonOverlay = _buttonOverlay;
                // Initialize UI elements
                usernameTextBox = new TextBox();
                passwordTextBox = new TextBox();
                loginButton = new Button();
                // Set form properties
                Text = "Login";
                Size = new Size(300, 150);
                FormBorderStyle = FormBorderStyle.FixedDialog;
                StartPosition = FormStartPosition.CenterScreen;
                //SetTitleColor(Color.Gray); //Code Not Worked
                // Set the AcceptButton to the loginButton
                AcceptButton = loginButton;
                // Add UI elements to the form
                var labelUsername = new Label { Text = "Username:", Location = new Point(10, 20), ForeColor = Color.Gray };
                var labelPassword = new Label { Text = "Password:", Location = new Point(10, 50), ForeColor = Color.Gray };
                //var labelUsername = new Label { Text = "Username:", Location = new Point(10, 20)};
                //var labelPassword = new Label { Text = "Password:", Location = new Point(10, 50)};
                usernameTextBox.Location = new Point(labelUsername.Right + 5, 20);
                passwordTextBox.Location = new Point(labelPassword.Right + 5, 50);
                passwordTextBox.PasswordChar = '*';
                loginButton.Text = "Login";
                loginButton.Location = new Point(10, 80);
                // Set the colors for the buttons
                //loginButton.BackColor = Color.FromArgb(255, 255, 255, 255); //Not worked.
                //loginButton.ForeColor = Color.FromArgb(255, 70, 70, 70); //Not Worked
                loginButton.ForeColor = Color.Gray;
                loginButton.BackColor = Color.White;
                //loginButton.BackColor = Color.Black;
                //loginButton.FlatAppearance.MouseOverBackColor = Color.FromArgb(255, 211, 240, 224);
                loginButton.FlatAppearance.MouseOverBackColor = Color.LightBlue;
                loginButton.FlatStyle = FlatStyle.Flat; //Added because color didn't change
                loginButton.UseVisualStyleBackColor = false; //Added because color didn't change
                //Do mission planner keep changing this parameter inside with
                  Application.EnableVisualStyles()??
                loginButton.Click += LoginButton_Click;
                Controls.AddRange(new Control[] { labelUsername, labelPassword, usernameTextBox, passwordTextBox, loginButton });
            private void LoginButton_Click(object sender, EventArgs e)
                string username = usernameTextBox.Text;
                string password = passwordTextBox.Text;
                // Add your login authentication logic here
                if (AuthenticateUser(username, password))
                    DialogResult = DialogResult.OK;
                    buttonOverlay.IsVisibile = true;
                    Close(); //Ensure it is closed well.
                else
                    MessageBox.Show("Login failed. Please check your ID/PW");
            private bool AuthenticateUser(string username, string password)
                // Replace this with your actual stored hashed password
                string storedHashedPassword = "Password Erased due to uploading code to forum"; // SHA256 hash of password
                using (SHA256 sha256 = SHA256.Create())
                    // Compute the SHA256 hash of the input password
                    byte[] passwordHashBytes = sha256.ComputeHash(Encoding.UTF8.GetBytes(password));
                    // Convert the byte array to a hexadecimal string
                    StringBuilder stringBuilder = new StringBuilder();
                    for (int i = 0; i < passwordHashBytes.Length; i++)
                        stringBuilder.Append(passwordHashBytes[i].ToString("x2"));
                    string inputHashedPassword = stringBuilder.ToString();
                    // Compare the hashed passwords
                    return (username == "username" && inputHashedPassword == storedHashedPassword);
            }//End of AuthenticateUser()
Below is the code that enable this Login Form in Main Plugin code :
loginForm = new LoginForm(buttonOverlay);
loginForm.TopMost = true;
loginForm.Show(); //Show() : Modaless, ShowDialogue() : Modal
Below is the code in Main Plugin code :
public override bool Exit()
     if (loginForm != null && loginForm.Visible)
          loginForm.Close();
     return true;
As you can see in the above code, it changes the button background color to white.
However, sometimes the button color becomes white, as per the code,
But most of the time, its color is green (Mission Planner’s default ‘burntkermit’ color).
So, I’m wondering if there is the code ‘Application.EnableVisualStyles()’ in the Mission Planner’s main code.
Can someone help me with changing the button color?
This is the login form what I intended.
but sometimes the button color becomes like picture randomly.
sometimes it is green(mission planner theme color) and sometimes it is white.
Picture for forum - white buttons
It seems that plugin’s UI (ex. RichTextBox) is affected by Mission planner’s UI theme after the plugin’s Load() function is called.
As a result, it seems difficult to apply custom color properties to my UI elments.
Does anyone have workaround or solution for this?
Any help would be greatly appreciated.
My current workaround is to update the color properties inside the Loop() function, like this:
public override bool Loop()
    Color darkGray = Color.FromArgb(70, 70, 70);
    form.warningBox.BackColor = Color.White;
    form.warningBox.ForeColor = darkGray;
    loopratehz = 5;
    return true;
However, this approach feels inefficient and not very clean, especially since both the main application and the plugin are updating the UI colors. I’m looking for a more elegant or centralized solution, if possible. :sweat_smile:
I found a solution.
My workaround was to set the loopratehz variable to 0 and place my UI properties setting code inside the loop() function.
This behaves similarly to loaded(), but it runs after the Mission Planner theme has been fully applied.
Returning false in loop() didn’t solve the problem—loop() continued to run periodically even when it returned false.
