Hello, I want to ask why is there a big difference between 4-5 min and 6-7 min. Are they affected with something else? Because the minutes should be separated by the same distance, right?
Another question is what are the numbers in the X axis below the graph? That says “Line Number (10^3)”
Last question, which other programs can I use to see the logs?
Thank you
