HI, maybe this has been raised before but is there anything that can be done about overlapping data on the HUD
Add some spaces to the beginning of the prefix.
You may wish to make use of the Quick tab below the HUD. Everything you have displayed there can be viewed in the Quick tab. Double click a value to customize it. Right click to customize the number of values displayed. There’s even a (slightly painful) way to display warning colors if you use Ctrl-F to bring up the “hidden features” menu.
Thank you, that works
Thanks for your reply
I do use the lower panel as well, just my OCD to have co-ords in the HUD as well
Thank You
When I put ‘lng’ and ‘lat’ into the ‘quick tabs’ they only display with two DP’s, can I increase that? for co-ords I usually like at least 6 DP’s
Thank you
Bumping this please, wonder if there is a solution
