Hi, Up to now everything I’ve tried has worked perfectly, but (always a but), just got to use the Heli Setup page and it displays as very long columns which cannot be adjusted and does not give access to the variables other than in the first table for servo function. Since all other pages work perfectly, is there a known formatting issue. It does not appear to be a scaling issue encountered on anther post.
Hello Eosbandi, it works fine if I switch to a windows machine but not on linux pop os
(my error in not being clear with my system). Goto work out how to add a screen shot.
Sorry I cannot help you with the windows version.
Despite the heroic effort by Michael, Linux version is still quite buggy.
I have run into a snag with a tail rotor servo that uses the low PWM values (760us centering). I had to initially set up the servo the full parameter list because the values were too low for the Heli-page. Once I had min/center/max roughly set however, I was able to do the fine adjustments on the heli-page or servo page.
