Mission Planner gstreamer-1.0-x86_64-1.14.4.zip cannot found error
The Gstreamer video stream is working in QGC perfectly but in Mission planner it is giving error.
Steps:
Firstly Mission planner detects gstream without any problem
Says to download something
Gives Error cannot found gstreamer-1.0-x86_64-1.14.4.zip
I have faced with the same problem.
Checked the MP sources and found:
if (System.Environment.Is64BitProcess)
output = Settings.GetDataDirectory() + “gstreamer-1.0-x86_64-1.14.4.zip”;
url = “https://firmware.ardupilot.org/MissionPlanner/gstreamer/gstreamer-1.0-x86_64-1.14.4.zip”;
else
output = Settings.GetDataDirectory() + “gstreamer-1.0-x86-1.14.4.zip”;
url = “https://firmware.ardupilot.org/MissionPlanner/gstreamer/gstreamer-1.0-x86-1.14.4.zip”;
        status?.Invoke(0, "Downloading..");
        try
            Download.getFilefromNet(url, output, status: status);
            status?.Invoke(50, "Extracting..");
            ZipFile.ExtractToDirectory(output, Settings.GetDataDirectory());
            status?.Invoke(100, "Done.");
        catch (WebException ex)
            status?.Invoke(-1, "Error downloading file " + ex.ToString());
So, depending on your system (32 or 64 bit) you can manually download zip archive:
or
and manually put in the directory “C:\ProgramData\Mission Planner”
And MP will successfully extract it.
Thanks mate. worked like a charm.
