I connected the pixhawk to the mission planner. Then I connected the gps to the pixhawk. But on the mission planner screen, I get gps: no gps error.
I use pixhawk orange cube+ and se100(gps).
Did you configure the serial port on the Cube for the GPS? Did you make sure that the TX and RX wires are swapped? (TX–>RX, RX–>TX). Did you power cycle the Cube after connecting the GPS? If you connected the GPS after powering on the cube then it won’t recognize it.
thanks problem solved
