[quote=“wjaxxx”]Hi coni
First, thanks for the debugging
I have found another bug related to GPS Time conversion to UTC. Leap seconds calculation was erroneous and time was being calculated locally. Not UTC
However it does not explain why you see 18 minutes difference.
Are both file creation and EXIF Time the same? Or is there any discrepancy?
As for the missed CAM message. I do not have an explanation. The only thing that could explain it is that there is a known bug in dataflash download from APM/Pixhawk. So maybe you could try to get the bin directly from the SD Card
For the location kml button it does not work in the tool I passed you. No worries[/quote]
although I’m programmer myself, I’m not familiar with Mission Planner source code, which language is used, I’m bit lazy too etc… So it is much easier if I can talk to you then do it hard way myself…
EXIF time - look at the attached image (GPS info is wrong but else is original)… it’s the first one in the row… if you look in the log again, you may calculate exact time difference… try to play with this a bit, maybe you find a bug…
I’ve downloaded the BIN file from the microSD card and then I used the tool in the MP to convert it to LOG file… maybe this tool makes a problem with CAM messages… I don’t know, I’m just guessing as anything here might have a bug…
it would be nice at the end to update the APM documentation : plane.ardupilot.com/wiki/common- … n-planner/ because right now it’s a mess when all the people are puzzled with the new georef tool without explanation…
