I apologise if this is the wrong thread but here are the problems. I laid up my new 2.6 after installing a new off board GPS/Compass, that performed well and without any issues. Yesterday I decided to take it out again and fired up Mission Planner and stupidly let it update to the latest build. When I tried to connect the APM I got this message
[attachment=1]error on connection.png[/attachment]
2cnd When I try to update to the latest firmware I get this
Help please as when it was put away it worked fine.
I have exactly the same problem. I’ve tried disabling the firewall but I still get the same problem. The firewall logs when enabled don’t show that it blocked anything anyway so I don’t think it’s the firewall. Previous version works fine. Presumably other people are using the latest version and can connect to the firmware server Ok.
Sometimes it depends on the Rev of firmware your are using and the Rev of Mission Planner for some menu functions. MP can fall behind advancements in the firmware in some cases.
