Hi Everyone
I have mission planner installed on windows which is working fine but on the VMware I have mission planner and its not letting me connect to tcp/udp 115200 else for the baud the menu is stuck at 111100.
I am not sure if its due to ip configuration but I followed all the process mentioned and still not sure and I did tried all the IP mentioned on host machine.
when you click the connect button, a dialog box should be opened to specify IP and port. so the dialog box didn’t open?
Hi Mustafa
No it didnt open also i got the final error as this
But, then I did the recent beta update and it fixed the problem with the udp but now as soon as I try to connect with the plane it shows connecting to Mavlink and the Mission Planner crashes!!
MFINFO failed with existing file for the port and after this image shown below it crashes…
after restarting mission planner it generates this error
