When I try to start listening on a UDP port, sometimes MP refuses, saying the port is already in use. netstat shows nothing for UDP. Restarting MP has no effect. Even restarting Windows doesn’t always solve the problem. This seems to happen with port 14550 specifically.
There’s got to be something very simple I’m missing.
It appears that as soon as MP starts, it opens a number of ports, including 14550 and 14551. I wonder if there is some bit of persistent data that tells it to open these specific ports (I’ve used both previously), and then it tries to open them again. Using 1.3.74 (build 1.3.7563.27684)
Thank you, @Michael_Oborne. I’m not sure how this is supposed to work. I have Ardupilot running on a Linux board, sending UDP packets to gcs:14550. MP comes up, it shows the connection icon as disconnected. I click “connect,” it asks me about the port, I say 14550, then it says it can’t because the socket is already bound. What should i be doing instead?
