hi all i an setting up new plane with a cube
the system runs on 2 x 2S with 2 cube power modules
it shows the right volts on charged battery but all ways red
could you send though a tlog?
ok, so this option is a little hidden.
at some point you have enabled battery speech warnings. there is a dialog in there that asks for a warning voltage. it uses that voltage to show the voltage as red when it drops bellow it.
