Ran into a snag yesterday. I created a simple 10 point circle area using the Mission Planner software and saved to my computer. I then opened in APM and made some modifications then resaved it over the existing file. When I went back to the Mission Planner software, the application stated that the file was unreadable.
Why is the two programs not cross compatible when working with mission plans?
All I did was move a couple points around then saved it in APM Planner. I then attempted to open it in Mission Planner and that’s when I received the error.
So I decided to conduct another test. See below. The two programs seem to be incompatible with each other and this possess a problem for folks who use both and for those who wish to share mission plans.
R,
Doug W.
Mission Planner (V1.2.99.2 build 1.1.5204.13817)
From the Flight Plan window I selected "Create WP Circle. I accept all default options and plotted 20 points. I then saved it as “MP Test.txt”.
APM Planner (v2.0.8)
From the Flight Plan window I selected “Load WP” and tagged the “MP Test.txt” radius file. After verification that the file loaded correctly, I selected “Save WP” and over wrote the original file. Nothing was modified prior to saving it. File was named MP Test APM.txt".
I closed Mission Planner and then restarted it to ensure a clean application with nothing displayed in the Flight Planner window. From the Flight Plan window I selected “MP Test APM.txt” file and upon it attempting to load received “Invalid Waypoint file” message.
