Not sure what’s up here, been using MP for a long time. Got prompted to restart after MS patched the laptop and MP now just hangs. It did open once after waiting 20 minutes. Tried a de-install then deleted the entire directory,re-installed but same issue persists…
Anyone else seen this on the 3/14 update release from MS?
Update for Windows 10 Version 1607 for x64-based Systems (KB4013418)
Cumulative Update for Windows 10 Version 1607 for x64-based Systems (KB4013429)
Security Update for Adobe Flash Player for Windows 10 Version 1607 (for x64-based Systems) (KB4014329)
It just opened again and seems normal, let me dig in the event log for clues. Laptop is dedicated for MP and runs no other apps.
Ok MP Console says…
Debug under mono MONO_LOG_LEVEL=debug mono MissionPlanner.exe
INFO Program - ******************* Logging Configured *******************
INFO Program - 64bit os True, 64bit process True
bus type BUS_TYPE_I2C bus 2 address (i2c addr or spi CS) 30 devtype DEVTYPE_HMC5883_OLD
bus type BUS_TYPE_SPI bus 8 address (i2c addr or spi CS) 1 devtype DEVTYPE_AK8963
bus type BUS_TYPE_SPI bus 8 address (i2c addr or spi CS) 3 devtype DEVTYPE_LSM303D
INFO MissionPlanner.MainV2 - Mainv2 ctor
INFO MissionPlanner.MainV2 - Loading config
INFO MissionPlanner.srtm - .cctor
INFO MissionPlanner.srtm - C:\ProgramData\Mission Planner\srtm
INFO MissionPlanner.Utilities.Speech - TTS: init, mono = False
INFO MissionPlanner.MainV2 - change lang to en-US current en-US
INFO MissionPlanner.Utilities.adsb - adsb stop
INFO MissionPlanner.Utilities.adsb - adsb stopped
INFO MissionPlanner.MainV2 - Create FD
INFO MissionPlanner.GCSViews.FlightData - Ctor Start
INFO MissionPlanner.GCSViews.FlightData - Components Done
INFO MissionPlanner.GCSViews.FlightData - Tunning Graph Settings
INFO MissionPlanner.GCSViews.FlightData - HUD Settings
INFO MissionPlanner.Common - getModesList Called
INFO MissionPlanner.GCSViews.FlightData - Graph Setup
INFO MissionPlanner.GCSViews.FlightData - Map Setup
INFO MissionPlanner.MainV2 - Create FP
INFO MissionPlanner.GCSViews.FlightPlanner - Reading MAV_CMD for ArduCopter2
INFO MissionPlanner.GCSViews.FlightPlanner - updateMapType invoke req? False
INFO MissionPlanner.MainV2 - Create SIM
INFO MissionPlanner.MainV2 - Saving config
INFO MissionPlanner.MainV2 - myview width 1366 height 705
INFO MissionPlanner.MainV2 - this width 1382 height 744
INFO MissionPlanner.MainV2 - Load Pluggins
INFO MissionPlanner.Plugin.PluginLoader - Plugin Load D:\Program Files (x86)\Mission Planner\plugins\MissionPlanner.Grid.dll
INFO MissionPlanner.Plugin.PluginLoader - Plugin Init Grid 1.0.6240.11552 by Michael Oborne
INFO MissionPlanner.Plugin.PluginLoader - Plugin Load D:\Program Files (x86)\Mission Planner\plugins\MissionPlanner.Gridv2.dll
INFO MissionPlanner.Plugin.PluginLoader - Plugin Init Grid 0.1 by Michael Oborne
INFO MissionPlanner.Plugin.PluginLoader - Plugin Load D:\Program Files (x86)\Mission Planner\plugins\MissionPlanner.SimpleGrid.dll
INFO MissionPlanner.Plugin.PluginLoader - Plugin Init SimpleGrid 0.1 by Michael Oborne
INFO MissionPlanner.Plugin.PluginLoader - Plugin Load D:\Program Files (x86)\Mission Planner\plugins\MissionPlanner.Stats.dll
INFO MissionPlanner.Plugin.PluginLoader - Plugin Init Stats 0.1 by Michael Oborne
INFO MissionPlanner.Plugin.PluginLoader - Plugin Load D:\Program Files (x86)\Mission Planner\plugins\TrackerHome.dll
INFO MissionPlanner.Plugin.PluginLoader - Plugin Init GPS Tracker Home Plugin 1.0 by Will Bryan
INFO MissionPlanner.MainV2 - Load Pluggins Done
Open MissionPlanner.GCSViews.FlightData FlightData
INFO MissionPlanner.GCSViews.FlightData - Activate Called
INFO MissionPlanner.Controls.HUD - Vendor: Intel
INFO MissionPlanner.Controls.HUD - Version: 4.0.0 - Build 10.18.10.4358
INFO MissionPlanner.Controls.HUD - Device: Intel® HD Graphics
HUD resize 457 363
HUD resize 457 342 (Hang starts HERE)
HUD 1 hz drawtime 288681 gl True
HUD resize 457 342 (Hang ends HERE)
HUD resize 457 340
INFO MissionPlanner.Utilities.httpserver - Listening for client
INFO MissionPlanner.MainV2 - Loaded 4825 airports
INFO DotNetOpenAuth - DotNetOpenAuth.Core, Version=4.3.3.13295, Culture=neutral, PublicKeyToken=2780ccd10d57b246 (official)
HUD resize 457 245
HUD resize 457 342
HUD 3 hz drawtime 148 gl False
INFO MissionPlanner.MainV2 - myview width 0 height 0
INFO MissionPlanner.MainV2 - this width 160 height 28
Connected to Altitude Angel.
Loading map data…
Map area 36.8976069901347, 36.8676069901347, -121.675022735596, -121.645022735596
INFO MissionPlanner.Utilities.Airports - getAirports - regen list
INFO MissionPlanner.Utilities.Airports - getAirports done 0 sec
Map area Loaded 36.8976069901347, 36.8676069901347, -121.675022735596, -121.645022735596
Map data loaded
HUD resize 457 468
HUD resize 457 342
HUD 1 hz drawtime 137 gl False
INFO MissionPlanner.MainV2 - myview width 1366 height 635
HUD 1 hz drawtime 66 gl False
HUD 1 hz drawtime 69 gl False
HUD 1 hz drawtime 68 gl False
HUD 1 hz drawtime 62 gl False
HUD 1 hz drawtime 67 gl False
HUD 1 hz drawtime 78 gl False
HUD 2 hz drawtime 76 gl False
