Mission Planner 1.3.25
I need to roll back my Mission Planner to an earlier version (Win 7) and trust that someone will be able to assist as the current release is causing problems (Arducopter).
I had to adjust the RCMAP channel settings to accommodate my DX8/S-Bus combination and successfully did so on an earlier release so that everything was working correctly and now that I have updated to 1.3.25, throttle movement on my transmitter on the Radio Calibration page shows as controlling Roll, aileron as controlling Pitch, elevator as controlling Throttle and rudder as controlling Yaw. If I load APM Planner, everything shows as being correct as per my setup on the earlier version of Mission Planner so the indication is there may be a problem with the current release?
@Reigate,
Did you save your full parameter file before updating to MP 1.3.25?
If you did, then you can load it back in and see if that helps.
Regards,
TCIII GM
[quote=“TCIII”]@Reigate,
Regards,
TCIII GM[/quote]
Unfortunately, I didn’t.
Surprisingly, if I connect to the Quad via telemetry, control indications in Mission Planner are correct but if I connect via USB, they are wrong. I have also reconfirmed that control indication are correct in the latest version of APM Planner.
MP 1.3.25, Arducopter 3.21
sBus Futaba mapping is OK (default) when connecting via USB.
Marc
