Mission Planner 1.2.70 - crash on launch
Hi All,
Does anybody encountered with Mission Planner crash on launch after installing last update?
OS: Windows XP SP3 with all updates installed running in Parallels Desktop
The crash log below:
Event type: Error
Event Source:. NET Runtime 2.0 Error Reporting
Event Category: None
Event ID: 1000
Date: 20/08/2013
Time: 8:24:44
User: N / A
Description:
Faulting application ardupilotmegaplanner10.exe, version 1.2.70.0, stamp 520f41e1, faulting module kernel32.dll, version 5.1.2600.6293, stamp 506bc5dc, debug? 0, fault address 0x00012fd3.
Data:
0000: 41 00 70 00 70 00 6c 00 A.p.p.l.
0008: 69 00 63 00 61 00 74 00 i.c.a.t.
0010: 69 00 6f 00 6e 00 20 00 i.o.n. .
0018: 46 00 61 00 69 00 6c 00 F.a.i.l.
0020: 75 00 72 00 65 00 20 00 u.r.e. .
0028: 20 00 61 00 72 00 64 00 .a.r.d.
0030: 75 00 70 00 69 00 6c 00 u.p.i.l.
0038: 6f 00 74 00 6d 00 65 00 o.t.m.e.
0040: 67 00 61 00 70 00 6c 00 g.a.p.l.
0048: 61 00 6e 00 6e 00 65 00 a.n.n.e.
0050: 72 00 31 00 30 00 2e 00 r.1.0…
0058: 65 00 78 00 65 00 20 00 e.x.e. .
0060: 31 00 2e 00 32 00 2e 00 1…2…
0068: 37 00 30 00 2e 00 30 00 7.0…0.
0070: 20 00 35 00 32 00 30 00 .5.2.0.
0078: 66 00 34 00 31 00 65 00 f.4.1.e.
0080: 31 00 20 00 69 00 6e 00 1. .i.n.
0088: 20 00 6b 00 65 00 72 00 .k.e.r.
0090: 6e 00 65 00 6c 00 33 00 n.e.l.3.
0098: 32 00 2e 00 64 00 6c 00 2…d.l.
00a0: 6c 00 20 00 35 00 2e 00 l. .5…
00a8: 31 00 2e 00 32 00 36 00 1…2.6.
00b0: 30 00 30 00 2e 00 36 00 0.0…6.
00b8: 32 00 39 00 33 00 20 00 2.9.3. .
00c0: 35 00 30 00 36 00 62 00 5.0.6.b.
00c8: 63 00 35 00 64 00 63 00 c.5.d.c.
00d0: 20 00 66 00 44 00 65 00 .f.D.e.
00d8: 62 00 75 00 67 00 20 00 b.u.g. .
00e0: 30 00 20 00 61 00 74 00 0. .a.t.
00e8: 20 00 6f 00 66 00 66 00 .o.f.f.
00f0: 73 00 65 00 74 00 20 00 s.e.t. .
00f8: 30 00 30 00 30 00 31 00 0.0.0.1.
0100: 32 00 66 00 64 00 33 00 2.f.d.3.
0108: 0d 00 0a 00 …
Issue update
I’ve tested new version of Mission planner in:
  1. Windows XP SP3 Russian edition 32 Bit with all updates installed (old installation) + Parallels Desktop 8.0 - result is crash
  2. Windows 8.1 Preview Professional Russian 32 bit (clean install) + Parallels Desktop 8.0 - result is crash
  3. Windows 7 Home Premium Russian 64bit edition (old installation) all updates installed standalone copy on notebook - result is crash
  4. Windows 8.1 Preview Professional English edition 64x (clean install) + Parallels Desktop 8.0 - working
It’s seems that the last update uses “something” not available or not properly working in localized versions of Windows or .NET Framework.
Any ideas, how to solve the problem?
@ultras,
You need to have the latest version of .NET framework which is 4.0 or 4.5beta.
I have MP working on both a Windows 7 and Windows 8 machine without a problem.
Regards,
TCIII Admin
[quote=“TCIII”]@ultras,
Regards,
TCIII Admin[/quote]
You are not right. The Mission Planners requires only 3.5 version installed. The installer ask for this before install.
Win XP and Win 7 systems have latest 4.0 version installed. Win 8.1 has 3.5 version installed. The only system among tested where MP is working - Windows 8.1 English not localized version with 3.5 .NET Framework installed. I guess you are not using the localized Russian edition of windows, that is why you have MP running without any problem.
@ultras
The MP boot-up window on my Windows 8 machine said that I needed .NET framework 4 or higher.
Regards,
TCIII Admin
this issue was a utf issue, and is now fixed
Thank you!
