Hello, I want to set my rover up to operate over the wifi network in a mine so that I can control it anywhere from the control room. I have spent the day researching options, but have yet to find a good tutorial or guide on how to do it.
The Ardupilot documentation talks about aspsync and mavproxy but these rely on the wifi from teh companion computer. I want to plug an access point into the RPi and connect to the flight controller as well as to run video (ideally from an IP camera).
Does anyone know of a good solution which is well documented?
I have the access point that is configured to the mine’s wifi network. It is much more powerful than the RPi access point and allows for external aerials.
What I need is essentially to set up a cat5 wired connection between mission planner and the RPi on the rover. The actual wifi link will be transparent.
it depends on how the mesh node on the rover handles the network connection. If it acts like a transparent client bridge, it should just passthrough the connection to the RPi. The RPi then gets a valid IP address from the DHCP server on your existing network.
APSync will stream over all available networks on the Pi.
You may need to edit the Pi’s network settings after installing the APSync image. You can do this by SSH’ing into the Pi and using nmcli to configure your network settings.
