Good morning. I reloaded my quadcopter firmware this morning and noticed that the initial parameter setup tab under |frame type is missing.
I have also tried re installing mission planner and then updating to Beta again.
Check that in your config.xml the line “displayInitialParams”: true, is there.
Or simply delete config.xml and start Mission Planner.
ok let me try that quick
The config.xml file is not there or are you talking about the Zerconf.xml
Documents/Mission Planner/config.xml
OK it is true, let me delete it
OK Andras it was an 1d10t problem, My frame was not defined
