Sometimes I’m a little disorganized and will misplace mission flight plans for repeated projects. Usually, I’d go to the downloaded dataflash of that flight and locate the logwp text file. Now the only thing in the Dataflash DL is the BIN file. What happened to all the text, gpx, kmz and param files?
You have to create them from the BIN file (click on the Create KML+gpx button on the DataFlash Logs tab and select the bin file to process)
yes from now in its an opt in feature, this is because we have some users generating 300+mb logs (i was testing with 1gb), and this was causing some issue.
