I was trying to use a combination of a Mauch monitor (onboard equipment) and esc monitoring via bdshot for my motors. But I would need to set my batt_sum_mask for those monitors. Nothing in 4.4.5 or 4.5 beta. Any other options?
It’s not missing.
BAT1_MONITOR, 4 for the mauch
BATT2_MONITOR, 9 for ESC
BATT3_MONITOR,10 for Sum
BATT3_SUM_MASK,3 to sum 1&2
Current Summed, Voltage averaged.
Great, I found it! Now do I calibrate Batt1 for voltage a current being a Mauch analog sensor? Both Batt1 and Batt2 are monitoring the same battery. I presume it’s flashing the correct current and zero because the motors/esc’s aren’t armed and running. Battery capacity entered in Batt 3?
