Missing advanced params
Hello! new version released 1.2.94 I believe, is missing the advanced params and full list. Hopefully this was an oversight?
It’s there, you have to say “Advanced View” now or something. I saw it briefly but can’t check right now. Not sure why it got hidden, but its there if you re-enable or whatever…
firmware.diydrones.com/MissionPl … ngeLog.txt
  • Mission Planner 1.2.94
    add simple/advanced view (shows/hides tabs) Planner settings > advanced to get it back
In 1.2.94
In order to Be able to look at and modify the Full Parameter list:
Go to the Config/Tuning Tab
Select the left menu “Planner” item.
At the bottom right of the page check mark the Advanced View item.
Click on the Config/Tuning tab again and the Advanced Params and Full Parameter list items will reappear in the left column.
:unamused:
I’d like to offer a few suggestions, as most normal commercial software users don’t read change logs:
  1. Pop up a screen after updating that forces you to view the change log :slight_smile:
  2. Perhaps if you are moving something, put in a place holder for a few versions to point to the new location
Other than that, spectacular job. Keep up the great work!
